Grazie per il benvenuto.
Nel tentativo di trovare una soluzione, sempre sul sito della MCS ho trovato la proposta da Ben's
https://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=12506&highlight=bllcdi2cscaricato libreria "bl_lcd_i2c.LIB" ed il listato, ho modificato esclusivamente gli indirizzi di SCL e SDA rispettivamente
Config Scl = Portb.3
Config Sda = Portb.4
'I2c LCD on Arduino Nano 16x2 display with backlight
$regfile = "m8def.dat"
$crystal = 8000000
$baud = 9600 ' baud rate
Declare Sub I2c_scan
Config I2cdelay = 10
$lib "i2c_twi.lib" 'hardware i2c/TWI
Config Twi = 100000
$lib "bl_Lcd_i2c.lib" ' AN #118 library from Kent
' with this addition
' * lds r27,{backlight}
' andi _temp2,&hf7
' or _temp2,r27
'LCD-display including backlight
'0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1
'1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6
'G 5 C R R E D D D D D D D D B B
'N O S W 0 1 2 3 4 5 6 7 L L
'D V N S
'PCF8574
'P7 = D7
'P6 = D6
'P5 = D5
'P4 = D4
'P3 = 1 = backlight on / 0 = backlight off
'P2 = E
'P1 = RW
'P0 = RS
Const Pcf_d4 = 4
Const Pcf_d5 = 5
Const Pcf_d6 = 6
Const Pcf_d7 = 7
Const Pcf_rs = 0
Const Pcf_rw = 1
Const Pcf_e1 = 2
Dim B As Byte
Dim A As Byte
Dim _lcd_e As Byte
Dim Backlight As Byte
Backlight_on Alias &H08
Backlight_off Alias &H00
Backlight = Backlight_on
_lcd_e = 192
Const Pcf8574_lcd = &H4E 'Defines the address of the I/O expander for LCD
I2cinit
'Call I2c_scan 'if you want to check if the PCF8574 is seen activate this
Wait 2
Cls
Home
Lcd "i2c-display" 'display this at the top line
Wait 1
Lowerline 'select the lower line
Wait 1
Lcd "Shift this." 'display this at the lower line
Wait 1
For A = 1 To 10
Shiftlcd Right 'shift the text to the right
Waitms 250 'wait a moment
For A = 1 To 10
Shiftlcd Left 'shift the text to the left
Locate 2 , 1 'set cursor position
Lcd "*" 'display this
Wait 1 'wait a moment
Shiftcursor Right 'shift the cursor
Lcd "@" 'display this
Home Upper 'select line 1 and return home
Lcd "Replaced." 'replace the text
Cursor Off Noblink 'hide cursor
Cursor On Blink 'show cursor
Display Off 'turn display off
Display On 'turn display on
'Now lets build a special character
'the first number is the characternumber (0-7)
'The other numbers are the rowvalues
'Use the LCD tool to insert this line
Deflcdchar 2 , 32 , 10 , 32 , 14 , 17 , 17 , 17 , 14 'replace ? with number (0-7)
Deflcdchar 0 , 32 , 4 , 32 , 14 , 18 , 18 , 18 , 13 'replace ? with number (0-7)
Deflcdchar 1 , 32 , 10 , 32 , 14 , 18 , 18 , 18 , 13 'replace ? with number (0-7)
_lcd_e = 128
Cls 'select data RAM
Rem it is important that a CLS is following the deflcdchar statements because it will set the controller back in datamode
Lcd Chr(0) ; Chr(1) 'print the special character
'----------------- Now use an internal routine ------------
_temp1 = 2 'value into ACC
!rCall _write_lcd 'put it on LCD
Sub I2c_scan 'check all devices on the I2c-bus
Print "Scan start"
For B = 0 To 254 Step 2 'for all odd addresses
I2cstart 'send start
I2cwbyte B 'send address
If Err = 0 Then 'we got an ack
' Print "Slave at : " ; B ; " hex : " ; Hex(b) ; " bin : " ; Bin(b)
I2cstop 'free bus
Print "End Scan"
End Sub
Compilato senza errori e programmato il micro (AtMega8) ma il display resta inattivo con la prima riga nera e la seconda chiara.
Tramite oscilloscopio ho verificato che su entrambi i pin SCL e SDA fossero presenti segnali.
Nel dubbio che fosse guasto il dispositivo con il PCF8574A ne ho acquistato un altro di diversa marca ( sempre con uguale pedinatura ), ma non cambia nulla.
La versione del Bascom è la 2.0.7.3
A questo punto non saprei cos'altro provare, ogni aiuto è il benvenuto.
