Strange Array Index Problem
Postby Sonic » 09 Aug 2011, 12:57
Hello,
i'm trying to indexing arrays with an ofset. But it doesn't work correct.
Dim Tmp_byte As Byte
Dim Timer_index As Byte
Dim Timer_load As Byte
Dim Pwm_table(10) As Byte
Dim Timer_table(10) As Byte
Timer_index = 0
Tmp_byte = Timer_index + 1
Timer_load = Pwm_table(timer_table(tmp_byte))
Print Timer_load ; " ";
Timer_load = Pwm_table(timer_table(timer_index + 1))
Print Timer_load
Pwm_table and Timer_table are filled with valid values, but i got different results for Timer_load.
What's wrong?
Thanks in advance
(Bascom AVR 2.0.7.0)
Sonic
Re: Strange Array Index Problem
Postby deluca » 10 Aug 2011, 10:00
Sonic wrote:Hello,
Timer_index = 0
Print Timer_load
What's wrong?
Thanks in advance
It may be that Bascom is having problems evaluating the index to an index:
Timer_load = Pwm_table(timer_table(timer_index+1))
Try rewriting this as
tmp_byte = timer_table(timer_index + 1)
Timer_load = Pwm_table(tmp_byt)
This is the same sort of problem that Bascom has with multiple term in an expression, like
a = b + c + d
